Deletes a tracking entry for the specified IP address.
| vlan_name |
Specifies the name of a VRRP VLAN. |
| vridval |
Specifies the VRID of the target VRRP instance. To display the configured VRRP router instances, enter the show vrrp command. |
| ipaddress |
Specifies the IP address to be tracked. |
N/A.
Deleting a tracking entry while VRRP is enabled causes the VRRP VRs state to be re-evaluated for failover.
A VRRP node with a priority of 255 might not recover from a ping-tracking failure if there is a Layer 2 switch between it and another VRRP node. In cases where a Layer 2 switch is used to connect VRRP nodes, we recommend that those nodes have priorities of less than 255.
The following command disables ping tracking for the external gateway at 3.1.0.1:
configure vrrp vlan vlan-1 vrid 1 delete track-ping 3.1.0.1
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
